MEFI-4 Idle Hunt at Start Mystery
- Been thanked: 1112 times
Re: MEFI-4 Idle Hunt at Start Mystery
- Delorean6855
- Vessel Info: 2004 Mariner Three Sixty, Crusader 6.0s w/225 hours, Koehler 7_3e genset
- Been thanked: 5 times
km1125 wrote:Source of the post That's interesting. Does that hose go right to manifold vacuum?
Yup, it's the oddest thing.
- Has thanked: 602 times
Maybe wrong here, but IF the ECU was designed to work with a PCV valve in the covers of each engine then they should be there. See if there is evidence of the PCV valves being removed for some reason.
is it like that on both covers on the same engine?Delorean6855 wrote:Source of the post Finally getting back to this... so this is where the PCV valve should be...I remove the hose and it's just a hose barb. Super weird... the 6.0 schematic says the engine should have one.....
BTW, take a closer look at that fitting that looks like a hose barb. Some PCV valves look exactly like that at one end and are threaded in at the other and look like a simple fitting.
- Delorean6855
- Delorean6855
The other valve cover hose goes to the flame arrestor, correct ?
