Lifters for 2001 Mercruiser 350 MPI
- Dark Horse
- Vessel Info: "Dragonfly"
2001 Carver 350 Mariner
Twin 350 MAG MPI - Location: Hudson, FL
- Has thanked: 1 time
- Been thanked: 6 times
One of the motors has a lifter tick I just cant eliminate.
I am going to put a new set of lifters in it (cause I don't know which one is ticking)
Are a set a Chevy lifters for the same year 350 the same?
Or did Mercruiser use something different?
2001 350 Mariner w/ 350 Mercruisers
Home Port - Hudson, FL
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Lifters for 2001 Mercruiser 350 MPI
Does the engine run fine and did the noise start right after spring start up ?
Somewhere around 2001/2002 GM changed to the LS1 engine, those lifters will not work in your motor, so you want to make sure you get the proper ones.
Before all that, are you sure it's a lifter, not and exhaust leak or something else?
Hate to see you tear down the top end and have the same issue.
- Dark Horse
- Hoplite808
- Vessel Info: 1988 Carver 3227 Convertible
- Been thanked: 8 times
https://www.wholesalemarine.com/mercury ... t1-lifter/
- Been thanked: 1111 times
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
Users browsing this forum: Google Adsense [Bot] and 16 guests
