1974 Carver Monterey 2585 Restoration
- Carver74
- Vessel Info: 1974 Carver Monterey 2585
Ford 302
Merc MC-1 outdrive
New to the forum. I just purchased a 1974 Carver Cabin Cruiser for $2500. I believe it is a Monterey, number 2585. It’s equipped with a Ford 302 and Mercruiser MC-1 outdrive.The engine runs and upholstery is in “decent” condition. The boat was last in the water 10 years ago and has been barn stored ever since. I know these hulls are balsa cored, which concerns me slightly. However this boat seems to have solid stringers, floor, and hull. Only time will tell if that is the truth. I will be restoring the boat this winter with my brother. It needs some interior upholstery work, teak restoring, re-wiring, and outdrive replacement/rebuilding. I plan to document my restoration on this thread and upload photos along the way.
Question for you all: Does anyone have any experience with this hull or have any knowledge to share on these types of Carvers?
- Has thanked: 598 times
- Been thanked: 1281 times
Re: 1974 Carver Monterey 2585 Restoration
Carver74 wrote:Source of the post Question for you all: Does anyone have any experience with this hull or have any knowledge to share on these types of Carvers?
First welcome to the forum......the only advice I can put forth here is simple, before spending one more dollar make sure the stringers /hull and especially the transom are ok.....you may have to take some core samples to make sure. These areas need some experience to inspect and repair properly and will be the basis of a solid and safe vessel later on when the pretty stuff gets in there.....good luck with your resto and I look forward to the pics as you go forward.......
- Has thanked: 78 times
- Been thanked: 1093 times
- Has thanked: 64 times
- Been thanked: 481 times
- Has thanked: 469 times
- Been thanked: 1765 times
- 74monterey
- Vessel Info: 75 Monterey 2585
302 Ford/Mercruiser - Location: Detroit
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
Start low around the plug hole and work out from there.
First test before drilling would be to tap with a hammer. Dull sounds are bad, sharp sounds are good.
