Carburetor for 7.5 KW Generator
- gctiii
- Vessel Info: 1990 Carver Montego 35. Closing on her 31 January if the items I noted are repaired. Twin 454 Crusaders in great shape. Port side needs a tune up. Mostly minor repairs.
- Has thanked: 2 times
I have a serious dilemma; I am looking for operable Carburetor to repair my generator made by Kohler. new or used (if operable and can be rebuilt is fine).
The model num is : 7.5R or 7.5R27 Serial Number: 197312
Spec is: 106276-A
Kohler part number is: 5005303 verified this in part's manual and stamp on carb.
Carb manufacturer mark is C-241227. The generator is getting a valve job and Carb is shot, no way to repair as electrolysis has eaten the air mixture shaft and the bolt. In all my years I have never seen so much damage. A rebuild kit will not fix the problem.
Please if any of you can help or point me to business to get one, I would greatly appreciate it. Kohler could not help they only make diesel generators now.
Thank you Gordon
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Carburetor for 7.5 KW Generator
- Been thanked: 601 times
As Bud mentioned, determine the engine make and model and you can hopefully find a new carb.
- gctiii
gctiii wrote:Source of the post I am going to try that next. Got to head back down to Gulfport this month and will find the make of the engine. I know it is a flathead 4!
Oh that is an old one......tractors, welding machines, utility generators depending on which model the engine is etc....check some yards down there.
Is yours cranked from a starter or the gen head/exciter ?
- Has thanked: 78 times
- Been thanked: 1093 times
- gctiii
The cost for a new generator is just crazy to be honest.
- gctiii
gctiii wrote:Source of the post The engine is indeed a four-cylinder flathead. It is currently apart as I have a sticking valve. No other damage to the engine except it is old. I normally head back to the boat monthly but children coming home this month for Thanksgiving.
Poking around a bit I am indeed shocked that they were still using flatheads into the 90s!! Definitely agree the new genset prices are crazy, or even beyond crazy these days. Even used ones have crazy prices. They've been very high for a couple decades but maybe they were always crazy high.
I also poked around for a bit to see if I could find some resources for a carb, but couldn't find any good leads.
- Has thanked: 469 times
- Been thanked: 1765 times
