Hull ID Number
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Hull ID Number
Postby tonyiiiafl » February 18th, 2016, 4:02 am
I have a 1994 Cockpit Motor Yacht. For the life of me I cannot find the Hull ID number! I have looked on the usual starboard side transom and also the side but NOTHING. Is there a secret spot or another place they may be? ANY help would be SO appreciated!
Been thanked: 491 times
Re: Hull ID Number
Postby waybomb » February 18th, 2016, 12:21 pm
I am pretty sure it <must> be on the Starboard transom, just under the gunnel.
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Hull ID Number
Postby Lyndon670 » February 18th, 2016, 7:10 pm
Your survey should show where it is. Not just show the HIN, but show where the HIN is.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Re: Hull ID Number
Postby Viper » February 18th, 2016, 7:29 pm
A couple of other spots to check are on the transom under the swim platform or on one of the stringers in the engine bay. Unusual though for it not to be on the strb aft quarter of the hullside or strb corner of transom under the gunnel.
tonyiiiafl
Re: Hull ID Number
Postby tonyiiiafl » February 19th, 2016, 4:46 pm
I spoke to Carver, and they said the HID # is NOT embossed into the fiberglass, but rather a plate with 2 screws holding it onto the transom. :banghead: They did say it was also fastened onto the stringer UNDER the starboard engine. Just a plate maybe 1.5" x 6". I am sure I am going to have a "hull" of a time finding it!
Re: Hull ID Number
Postby Viper » February 19th, 2016, 7:03 pm
No it's not embossed into the fiberglass, it is as they say, a white plastic plate fastened to the hull. Check out the top right picture in this link, the one with the label under it. It is not a Carver # but the plate is very similar.
http://www.customboatrepairs.com/jmla/index.php?option=com_content&view=article&id=48:tips-on-buying-a-used-boat&catid=8:boat-buying-tips&Itemid=7
tonyiiiafl
Re: Hull ID Number
Postby tonyiiiafl » February 20th, 2016, 9:01 am
I am now on the hunt! Thank you!
Re: Hull ID Number
Postby Viper » February 20th, 2016, 10:31 am
Let us know what you find.
Users browsing this forum: No registered users and 67 guests
