Dinette cushions
- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
Dinette cushions
Re: Dinette cushions
I think denim could look very nice, but I'd be sure to Scotchguard it well before use.
- Been thanked: 654 times
- Grafunkus
- Captain
g36 wrote:Source of the post Not making a pro or con but curious why denim? Just asking.
I thought it would be a hard wearing fabric (jeans). Depending on the demin, the feel of it can be quite nice. Easy to find and work with. Just some of my thoughts as to why.
- Grafunkus
- Captain
km1125 wrote:Source of the post The one thing that is tough (that we didn't get right) was the angle on the back of the center cushions, to accommodate the angle of the hull.
I don't plan on making the cushion that rests on the hull. That is where I plan to use loose body pillows or toss cushions. I brought the "seat" cushion home to trace the pattern onto new foam. I guess I will have to consider the angle from the top of the cushion to the bottom, but not sure 2" depth is a big concern. Or is it?
Grafunkus wrote:Source of the post
.... I brought the "seat" cushion home to trace the pattern onto new foam. I guess I will have to consider the angle from the top of the cushion to the bottom, but not sure 2" depth is a big concern. Or is it?
Certainly not as big of an issue as the top cushion, but if you put in the effort to accommodate that angle it will fit nicer.
2" sounds thin though... I think the originals were 3". If you go with 2" make sure you use a heavy enough density foam, otherwise the framing on the seat supports will be uncomfortable to the underside of your legs.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Grafunkus
- Captain
km1125 wrote:Source of the post 2" sounds thin though... I think the originals were 3"
Good to know that the 3" were the original size. We tested out a 4" and it was waaay to thick.
