New to me Santa Cruz repower
- Georgia
- Vessel Info: 1977 carver Santa Cruz 2566 omc electric drive currently under repower
- Has thanked: 602 times
Re: New to me Santa Cruz repower
So the only wisdom/advice at this point would be to make sure that the hull/stringers/decks and especially the transom are in good shape before you go ahead with any refurbish. By good shape I mean free of inside rot, not soft. You may have to have the help of an expert if you are not comfortable inspecting and making the call.
Good luck with your project.....
- Georgia
I'd be very surprised if that 6.2L didn't provide a LOT more torque then the original 351 motor, but it won't be rated for as much horsepower just due to the limit on the top RPM. The torque is what could kill the outdrive though. You need to make sure you also have a coupler that can handle the torque and also absorb the torque spike as each cylinder fires, so that those don't get transmitted directly to the outdrive.
We had another member convert an outdrive boat from gas to diesel, but his was only a FOUR cylinder. His purpose was fuel economy and long distance cruising and he's been running that combo for about five years now (great thread... called something like "Little boat, big project!")
Fuel economy would have a LOT of variables, but primarily how YOU are planning to use the boat and what speeds you'd be cruising at.
- Georgia
- Georgia
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
A diesel requires a carefully calculated and sized torsional vibration damper, and that OMC was sort of delicate, mine was! I would not recommend installing a diesel. Custom installation is tricky, expensive and time consuming. When I worked for a major marine gear manufacturer, I tested many drive packages where the damper was not correct and the gear was ruined. BIG gears! EXPENSIVE gears!
You could get back on the water so much quicker and easier if you just put an identical engine back in, re-using any salvageable marine parts. I think there are many salvageable 351's out there that could be easily majored, and give you many years of reliable service.
Any particular questions, feel free to pm me.
- Been thanked: 654 times
Users browsing this forum: Google [Bot] and 26 guests
