2001 356 aft cabin getting water in the rear bilge
- Ron@murr.biz
- Vessel Info: 36 ft. Carver motor yacht
- Been thanked: 2 times
- Has thanked: 602 times
Re: 2001 356 aft cabin getting water in the rear bilge
Do you have muskrats/critters that like exhaust inlets where you are ?
- Ron@murr.biz
I don't recall if water in the bilge of that model can run unimpeded from one section to another. If it can, it can be originating anywhere. If you've ruled out the shaft and rudder logs, exhaust, AC, etc., I would run the engines one at a time above idle and look for leaks. It's likely that you have closed cooling but there will be a raw water circuit that should be inspected.
What engine package do you have?
Did you check the shaft logs in gear, and the exhaust with the engines running?
- True-North
- Vessel Info: 1997 Carver 355 Aft Cabin, lower helm station, Crusader 454 XLi engines, owner since 2007.
- Has thanked: 12 times
- Been thanked: 4 times
- Ron@murr.biz
- pondiscio@gmail.com
- Vessel Info: Carver 430 1995 "Wonder More"
- Has thanked: 3 times
- Been thanked: 11 times
- Ron@murr.biz
