TracVision C3 help
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 23 times
TracVision C3 help
So, I was told by someone the TracVision is too expensive to subscribe to and antiqueted. I Can’t get info from previous owner, but looks to me like it’s a similar setup as I have in the RV? From what I can surmise from KVH website, the C3 satellite is just an in-motion satellite dish that needs either DirecTV or Dish receiver to make a complete system?
Yes, I know I can use one of the connection devices (I.e. Roku, Firestick, Apple TV, etc, etc) to get programming if I have cellular internet. But if I can use the TracVision with my Dish Network receiver, that would be great. I’m aware also that the satellite will not get service under the metal roof of the slip and the satellite receiver/dish will only work on open sky.
Does anyone have experience with the TracVision C3 system?
Thanks!
1979 Caravelle 18’
- Been thanked: 646 times
Re: TracVision C3 help
- Been thanked: 1180 times
- Mikwallace
Here’s a pic:
It appears to be a “Booster” maybe???
I removed it and opened it but there’s not a single part number on it. Tried Google but didn’t find anything there either.
Can someone ID this for me and if possible it’s purpose!
Thanks.
1979 Caravelle 18’
- Has thanked: 78 times
- Been thanked: 1093 times
What kind of antenna do you have? Could also be a distribution amplifier (or 'booster') for the signals too.
https://maxview.co.uk/product/masthead-power-supply/
- Mikwallace
km1125 wrote:Source of the post Could be a power supply (takes ~12V power and puts in on the Coax center conductor) for an amplifier in or at the antenna.
I’ll have to find the antenna. But this thing runs on 120vac.
1979 Caravelle 18’
Mikwallace wrote:I’ll have to find the antenna. But this thing runs on 120vac.
Yea, that's how those kind of power supplies work.
120 in, converts it to a lower DC voltage (or even a lower AC voltage in some cases, but that's more rare), then then puts that voltage on the Coax cable going up to where the amplifier is, which could be inside the actual antenna or right next to it. It is typically done when the antenna is high up in a tower, so you don't have to install a 120V outlet up on the tower and have that also exposed to the elements.
- Mikwallace
1 - stay with DirecTV SD version (of which DirecTV does not have an ON/OFF subscription like DISH Network and I have DISH at home and RV)
2- Buy a new In-Motion Satellite Dish which is $$$$ (Add this to Future Addition projects)
3- Use Cell Phone Personal Hotspot and WiFI to ROKU When on the Hook and Marina WiFI
1979 Caravelle 18’
