Follow up question to fuel smell in the salon
- denpooch
- Has thanked: 85 times
- Been thanked: 87 times
A couple of months ago I posted regarding a fuel smell in the salon. After many responses, I have decided to change out the fuel fill hose on both port and starboard this Spring. Folks have noted that hoses can be compromised due to the age of the boat and additives in the gasoline. I have a 2005 Mariner.
I was speaking with a friend and he mentioned that perhaps the fuel 'vent' line is the culprit.
I do not recall seeing any vent line on the boat. My previous vessel had the vents on the hull near the fill which were easily observed.
Do all boats require a fuel vent line?
Does the Mariner have a fuel vent line? If so would you know where they live.
Many thanks.
- Been thanked: 646 times
Re: Follow up question to fuel smell in the salon
https://www.perko.com/catalog/fills_and ... inch_hose/
- Has thanked: 78 times
- Been thanked: 1093 times
- Has thanked: 469 times
- Been thanked: 1765 times
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 36 times
Before operating this boat again, you MUST find the source of leakage and eliminate the leak. ANY gasoline odor is unacceptable!
That said, the fuel fill hose is a likely culprit on a boat of that age, or the tank spigot flange gasket. It is less likely (although still possible) that the aluminum tank would be leaking due to corrosion or seam failure.
Another POTENTIAL source of leakage would be if filling full on a cold day, and then the ambient temp. goes up substantially, the fuel could be expanding and being pushed out the vent, or out the fill flange on the tank top. But if the level is lower then the odor is coming from a lower source and is even more serious because it will be continuous.
Remember, one cup of gasoline, fumed, equals 6 sticks of dynamite. Good luck finding your leak!
- denpooch
- Jay Fusaro
- Vessel Info: 1998 445 Aft Cabin
- Has thanked: 75 times
- Been thanked: 3 times
AquaVilla
- Wsullivan71
- Vessel Info: 2001 Carver 404 Motor Yacht
- Been thanked: 12 times
