Onan generator runs with no fuel pump?!?
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 125 times
- Been thanked: 123 times
I traced it to a high current draw on startup and by process of elimination narrowed it down to the electric fuel pump. And during that process, after disconnecting the electrical leads to the fuel pump, I started the generator to monitor the current draw. I expected it to run briefly then shut off since the fuel pump was disconnected. Unexpectedly the generator ran great - and continued to run fine for 3+ hours. And I've probably added close to 10 more hours over the rest of the weeknd and today. All without the fuel pump connected electrically.
The only thing I can figure is that the fuel level in the tank is higher than the generator injectors and must have enough elevation head to ovecome all the flow restrictions, including a Racor filter and the non-working fuel pump. Does this sound right?
My real question is this: will running our generator without a working fuel pump cause any unforseen problems (short or long term) with the generator? I plan to replace the fuel pump when we get back to a marina but wanted to make sure I am not doing any damage like it is.
Thanks for any info!
Kyle
2002 Carver 396
- Has thanked: 587 times
- Been thanked: 1248 times
Re: Onan generator runs with no fuel pump?!?
- KyleR
2002 Carver 396
2002 Carver 396
Good info for others...
- KyleR
2002 Carver 396
2002 Carver 396
- Has thanked: 74 times
- Been thanked: 1060 times
