E01 error Code on Salon hvac
Re: E01 error Code on Salon hvac
Postby Viper » February 16th, 2023, 6:41 am
Have you checked your owner's manual to see if there's a programable setting for that?
Postby km1125 » February 16th, 2023, 8:37 am
As Viper notes, that is probably programmable. Do you know exactly which controller you have? Some look similar but have different versions that have different programming techniques or features. Some you can differentiate on whether or not it has a "snowflake" icon on the button or case. Post a pic of the controller if you don't know, and someone may be able to ID it by sight.
Mikwallace
Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
Has thanked: 117 times
Been thanked: 23 times
Postby Mikwallace » February 17th, 2023, 12:24 am
km1125 wrote:Source of the post As Viper notes, that is probably programmable. Do you know exactly which controller you have? Some look similar but have different versions that have different programming techniques or features. Some you can differentiate on whether or not it has a "snowflake" icon on the button or case. Post a pic of the controller if you don't know, and someone may be able to ID it by sight.
By the “controller”, are you referring to the wall mounted thermostat or the box mounted next to the compressor/air handler unit?
I thought the two thermostats and units were identical except for the BTU sizes. I’ll look and post pics of the thermostats when I go back to the marina. It’ll be a couple weeks as we’re headed out of town to visit grandkids.
I read through the manual, but only have one manual and can’t remember if it’s the Salon or Fwd unit. Both units are Webasto and are new, installed last summer.
Thanks for the guidance!
Standby.
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Postby Viper » February 17th, 2023, 6:41 am
Programming options are usually accessed through the wall mounted control by utilizing the buttons in a specific manner. The process should be explained in your manual if these options are available.
Postby km1125 » February 17th, 2023, 7:48 am
Mikwallace wrote:Source of the post
Yes.
They're referred to as a "controller" now because they do so much more than just an on/off for temperature like the old "thermostats".
The controllers can do things like varying fan speed and controlling humidity rather than just heat and cool.
Postby bud37 » February 17th, 2023, 1:17 pm
Does your stuff look like this ....? Check link below.
http://www.techwebasto.com/old/marine_m ... Manual.pdf
Mikwallace
Postby Mikwallace » February 17th, 2023, 1:21 pm
Here’s pictures of the wall controllers (thermostats). They look identical?
This is the Salon/Aft HVAC 16k BTU unit controller.
It would not let me post two pictures??
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Mikwallace
Postby Mikwallace » February 17th, 2023, 1:35 pm
bud37 wrote:Source of the post Does your stuff look like this ....? Check link below.
Yes, it looks like that.
I have an installation Manual but not the “Quick Reference Operation Guide”. Maybe there’s info in it to help. Also, I’ll print that and carry on-board.
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Mikwallace
Postby Mikwallace » February 17th, 2023, 1:51 pm
My Remote is different. My remote is type: YX1F
The controller looks the same.
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Postby km1125 » February 17th, 2023, 2:23 pm
Well, it could be as simple as this:
"Press the FAN button, the fan speed will change in the following order:
→ HIGH →MID → LOW → AUTO"
