Fuel consumption 4207 with Mercruiser 350s
bobwhorn
Vessel Info: 1989 Carver Santego 3867. Repowered with Cat 3116s in 1993.
Has thanked: 3 times
Postby bobwhorn » February 19th, 2023, 11:18 am
Is there a chart of fuel consumption at different sppeeds/RPMs? Coming from a sailing background where that was never an issue.
Thanks,
Bob
Has thanked: 64 times
Been thanked: 481 times
Re: Fuel consumption 4207 with Mercruiser 350s
Postby waybomb » February 19th, 2023, 5:53 pm
Simple rule of thumb. One half pound of fuel for each horsepower per hour.
Gas weighs 6 pounds per gallon.
So let's say you are using 300 hp between the two. That's about 25 gallons an hour.
If you are wide open, 700 hp, 60 gallons an hour.
It's expensive to run this boat with gas engines.
Been thanked: 646 times
Postby g36 » February 20th, 2023, 10:26 am
This website is a good place to check for estimated use...https://www.boat-fuel-economy.com/outbo ... us-gallons
bobwhorn
Postby bobwhorn » February 20th, 2023, 12:48 pm
Messed up, the engines are blue so I am told they are Crusader 454s.
Postby g36 » February 21st, 2023, 11:18 am
Same website just select crusader and the engine displacement and see estimated fuel flow at various rpms.....https://www.boat-fuel-economy.com/crusa ... us-gallons
bobwhorn
Postby bobwhorn » February 21st, 2023, 1:07 pm
Thanks, missed the part about selecting engine type and size.
MyPleasure
Has thanked: 2 times
Been thanked: 21 times
Postby MyPleasure » April 4th, 2023, 3:16 am
Hi bobwhorm, I’m not sure that that website uses the Crusader carbureted 7.4 or just the MPI engine’s specifications. You might find that the carbureted 7.4’s will use a bit more fuel than the fuel injected 7.4’s. Our 1992 Carver 36ft aft cabin with carbureted Volvo 7.4 engines use about 5gph each (according to the fuel floscans) at 1500rpm, giving us a cruising speed of about 8.5 knots.
Just to give you a real time example of fuel use.
Al
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
MyPleasure
Postby MyPleasure » April 4th, 2023, 3:21 am
And by the way, the 4207 is a much larger boat than our 36 in every way, so your fuel consumption would probably be even more than our 5 gph at the same 8.5 knots!
Al
