Seacock frozen
Netherlands
Phrancus
Has thanked: 16 times
Been thanked: 136 times
Re: Seacock frozen
Postby Phrancus » March 7th, 2023, 4:58 pm
Sounds like you think he means cold frozen however the wording can be misleading. He is saying the valve is stuck and will not close any more, nothing to do with freezing cold. ;-)
Correct, thanks, learned something today.
Now for a completely different idea (might sparkle creativity towards a solution) :
First test: water in a glass, rust-remover on top. If it floats you have a way to soak the ball. If not move on:
Second test: bit of sunflower oil in a glass. then pour some rust-remover on top slowly. See if it stays on top you can use this to soak the ball. If it dissolves the oil, move on to other measures.
Insert a tampon beyond the ball, then pour in rust-remover and let it soak.
:-D
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 143 times
Been thanked: 134 times
Re: Seacock frozen
Postby KyleR » March 7th, 2023, 5:19 pm
And to add - if you are planning to pull the hose to the valve then you could also pour some Barnacle Buster down in there. You might have a scale buildup that the BB might help dissolve.
MV Verity
2002 Carver 396
Has thanked: 78 times
Been thanked: 1093 times
Re: Seacock frozen
Postby km1125 » March 7th, 2023, 5:29 pm
KyleR wrote:Source of the post And to add - if you are planning to pull the hose to the valve then you could also pour some Barnacle Buster down in there. You might have a scale buildup that the BB might help dissolve.
Yea, this is more likely the issue (or marine growth in general) than rust or corrosion.
The ball itself is a plastic and can slightly disform if left in the same position for way too long. That alone would make it difficult to get starting to move.
