Zinc Anodes
- ehschneider
- Vessel Info: 36 Carver Mariner
Zinc Anodes
What size are they? Is there a simple directory that lists them with sizing for a vessel? My boat is in storage 3 hrs from here and I wanted to order them.
2006 Mariner. THANKS!!
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Zinc Anodes
My 01 had one on each shaft, one on each trim tab and the divers dream type plate on the transom.....the balance of the fittings were all bonded.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Zinc Anodes
Re: Zinc Anodes
Re: Zinc Anodes
bud37 wrote:Source of the post One other question....do you have thrusters bow or stern ?
Hmmm, have I missed this one? Both my Side Power brand stern and bow thrusters have composite props so I assume they have no anodes?? https://www.getaprop.com/bow-thruster-p ... -propeller
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Zinc Anodes
Re: Zinc Anodes
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
Re: Zinc Anodes
Your shaft is probably 1-3/8, but measure. Your hull is 6x12 and the rudders are usually 3".
I go to Performance Metals for my anodes because their pencils (cooler) anodes have a steel rod in the middle to prevent aluminum from breaking off inside the cooler. They say they don't sell direct, but call them and they usually will.
Phil Little '92 Carver 350 Aft Cabin
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Re: Zinc Anodes
a. 1 1/2" shaft zincs. I tend to 'over zinc' because of stray current in my marina so I have 2 on each shaft.
b. Block zinc on the stern. The bolt holes are 5" apart. Be sure that below, in the most stern engine room where the green bonding wires terminate; the nuts are well tightened. Also, make sure the bolts coming through the boat to the zinc shaft are also tightened. My were not and caused some slight issues.
c. I have a 5" disc zinc on each trim tab
d. 1/4" pencil zincs in the engine heat exchangers and on the generator if so equipped.
e. Bow thruster zinc. Round 'button' that is affixed to center of propeller.
That's it. If you have questions on your vessel please feel free to ask. I am pretty familiar with the boat. They are great and your friends are gonna love it.
