Sea cock stud to hold handle on broke, can it be replaced
- nmcap
- Vessel Info: 1999 Carver 406 aft cabin motor yacht
twin 454 crusaders
The valve works fine...just the handle wont stay on.Dont really want to replace the whole thing. Cant find any assembly illustrations...looks like it is just a screwin stud ... afraid the ball assembly will fall out if i just unscew it ... has anyone ever replaced this? Where did you get the parts...any info would be appreciated.[image][/image]
- Been thanked: 1180 times
Re: Sea cock stud to hold handle on broke, can it be replaced
- Has thanked: 78 times
- Been thanked: 1093 times
And, technically, that's not a sea cock but just a ball valve. If it had the flange integrated with it then you'd call it a sea cock.
- nmcap
twin 454 crusaders
sea cock
That would be a rooster that swims or a description of an old salt's private parts.
- Has thanked: 598 times
- Been thanked: 1281 times
Are you on salt water and is the boat in the water now ? Can you get a real good look at the break there, is there any evidence of corrosion weakening the shaft. If so consider replacing that valve and have a good look at the thru hull fitting there with all the green on it. Many times they fail from the inside with no warning. Seems odd where the break point is to me anyways.
Could be just fine but I am suggesting have a good look so you don't have problems when away from port.
- Has thanked: 468 times
- Been thanked: 1765 times
Viper wrote:Source of the post Replace the valve! They don't have to haul you out completely to do the job, just get you a little above the water and leave you in slings. The valve can be replaced while in the water but I wouldn't attempt it on a valve that's been in salt water because you don't know the condition of the thru-hull intake. I wouldn't do a bush fix here, by drilling a hole in the shaft you weaken it further which is just asking for trouble at a time when you need it most, and if the worst happens, that'll be your insurance company's way out of a claim. Fix it properly.
If I had to make recommendations, I'm with Viper on this one.
There's a difference between what you "can do" vs what you "should do". Drilling might be a temp solution, as would the epoxy but neither should be considered the final solution.
Users browsing this forum: No registered users and 52 guests
