Battery charger settings
Jay Fusaro
Vessel Info: 1998 445 Aft Cabin
Has thanked: 75 times
Been thanked: 3 times
Postby Jay Fusaro » April 6th, 2023, 12:58 pm
Hi all- I have a TrueCharge2 40A charger for my 2 8D flooded batteries. We recently bought our boat ('98 445 w/Cummins 8.3L engines). My question is - which Charge Mode is best? The prior owner had it set to "2 Stage" which is Bulk and absorption. The default setting on the charger is "3 Stage" which is Bulk, absorption and float. I don't know why he would use "2 Stage"? It seems to me that "3 Stage" so it's on float would be better. I would appreciate any advice and feedback.
Thanks!
Jay
Jay Fusaro
AquaVilla
Has thanked: 78 times
Been thanked: 1093 times
Re: Battery charger settings
Postby km1125 » April 6th, 2023, 1:38 pm
If you have three stage available, I'm not sure why you wouldn't use it - especially if the batteries are regular lead-acid or AGM. Some gel batteries don't like the higher float voltages though.
Jay Fusaro
Postby Jay Fusaro » April 6th, 2023, 1:50 pm
Thank you I agree - they are lead-acid. I'm not sure why the prior owner chose to not use the float option on the 3 Stage.
Jay Fusaro
AquaVilla
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » April 6th, 2023, 2:22 pm
Jay Fusaro wrote:Source of the post Thank you I agree - they are lead-acid. I'm not sure why the prior owner chose to not use the float option on the 3 Stage.
Does it happen to give the charge time lengths for the different settings in the manual ?.......it may simply be, he didn't realize it or never left the boat plugged in so float wasn't an issue.....just a guess on my part though.
Been thanked: 1180 times
Postby Midnightsun » April 6th, 2023, 3:13 pm
Agreed, 3 stage is what you want. Weird things happen though. When I swapped out my factory Charles charger found out it was set to AGM however they are lead acid. You needed to unscrew the charger from the wall as the settings switch was located in the rear of the unit. :confused: Not really a good place to put it. Then again they have built cars where you need to lower the engine to change plugs.
Jay Fusaro
Postby Jay Fusaro » April 6th, 2023, 3:39 pm
I was just looking in the manual and it doesn't give the charge lengths - it simply describes what bulk and absorption are and that once the proper charge level is reached it will shut off.
Jay Fusaro
AquaVilla
Jay Fusaro
Postby Jay Fusaro » April 6th, 2023, 3:41 pm
Midnightsun wrote:Source of the post Agreed, 3 stage is what you want. Weird things happen though. When I swapped out my factory Charles charger found out it was set to AGM however they are lead acid. You needed to unscrew the charger from the wall as the settings switch was located in the rear of the unit. :confused: Not really a good place to put it. Then again they have built cars where you need to lower the engine to change plugs.
No doubt! I just wasn't sure if I was missing something. Maybe some people think leaving it on float will cook the batteries??
Jay Fusaro
AquaVilla
