Over heating port engine
Jay Fusaro
Vessel Info: 1998 445 Aft Cabin
Has thanked: 75 times
Been thanked: 3 times
Re: Over heating port engine
Postby Jay Fusaro » April 7th, 2023, 11:56 am
All good information guys I really appreciate it! I have taken screenshots of your comments and forwarded them on to the mechanic. Hopefully we have a resolution soon. If you have any more ideas I am certainly open to hearing them and sending them along.
Jay Fusaro
AquaVilla
Jay Fusaro
Postby Jay Fusaro » April 7th, 2023, 5:46 pm
Phrancus wrote:Source of the post When taking things apart, flush parts with a hose in both directions and check where it comes out. Easy if the boat is on land but in the water try to have an exit hose flush into a bucket/strainer. The first so you can dislodge a piece that is stuck in the usual direction of the flow and the latter to make sure that you know what did come out.
I've had this with my engines (with sterndrives) and you just keep worrying if you flush, solve the issue but are not sure you got it all out. In fact, the problem reoccurred some time later after a piece that was moved by the flushing relocated itself. Luckily it came out right at the first hose I disconnected but it was not a good experience.
It's a big design failure that a desintegrating impeller can move upflow in big enough pieces to block a heat exchanger.
Excellent idea - thank you!
Jay Fusaro
AquaVilla
Jay Fusaro
Postby Jay Fusaro » April 8th, 2023, 2:20 pm
Good idea on the flushing! Thank you.
Jay Fusaro
AquaVilla
