Identifying Green vent on bottom of hull
theorifice
Vessel Info: 1987 Carver Santego 30
Has thanked: 16 times
Been thanked: 4 times
Postby theorifice » April 18th, 2023, 11:51 am
What is this green vent? It is located on the aft of the hull and the vents are facing aft
Fun times on the 1988 Carver Santego 30
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: Identifying Green vent on bottom of hull
Postby Cooler » April 18th, 2023, 12:01 pm
That is the water pick up for your engines. The green is corrosion. Should have 1 for each engine. 8-) er
Cooler By The Lake
Been thanked: 1111 times
Postby km1125 » April 18th, 2023, 12:16 pm
Like Cooler says, those are typically for the engine or generator water intake. However, you wrote that the "vents" are facing AFT. Is that accurate? They should be facing forward if they are for engines or generator.
And there should be a coat of bottom paint on those, but don't lay it on so thick as to plug up the slots.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » April 18th, 2023, 12:36 pm
Could also be air conditioning water pick up
Postby g36 » April 18th, 2023, 12:48 pm
Or raw water head
Been thanked: 1310 times
Postby bud37 » April 18th, 2023, 5:33 pm
Looks like there has just been some work on it by the look of the sealant and the clean gel around it.
Postby Viper » April 18th, 2023, 5:56 pm
Check to see if it's for the generator. It's common to see that type of intake facing aft for generator applications so you don't force water up into a generator that's not running while the boat is underway. If the generator isn't running and water is forced through the raw water pump, there's no exhaust pressure to prevent water from backing down the exhaust elbow into a cylinder.
theorifice
Postby theorifice » April 18th, 2023, 10:25 pm
Thanks all.
The boat is a sterndrive so the water pickups are in the lower units. The boat does have AC and a generator. I saw a coolant reservoir for the generator though so it might be a closed system. I'll keep poking around and mapping out all of the fittings.
I'm not aware of any work in the last 3 years. We've owned for the last 8 months and previous owner hadn't done any work other than winterizing.
Postby tomschauer » April 18th, 2023, 10:56 pm
Even a closed cooling system for your generator uses raw water to cool it. It goes through a heat exchanger.
Postby Midnightsun » April 19th, 2023, 5:20 am
As explained above closed cooling systems need raw water to cool the coolant since everything is enclosed in a hot bilge unlike a car which can benefit from cooler ambient air and a radiator to do the same job.
Users browsing this forum: No registered users and 40 guests
