Bilge Pump Setup
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
Bilge Pump Setup
What would you do?
Re: Bilge Pump Setup
https://www.amazon.ca/XMSound-750GPH-Marine-Shower-System/dp/B08YQD52F8/ref=lp_2438577011_1_1?sbo=RZvfv%2F%2FHxDF%2BO5021pAnSA%3D%3D
- Been thanked: 1111 times
They can work pretty good and the pump can be disassembled and cleaned if it's not working well. They are pretty reliable with the Rule float switch, but you can get debris in there that will keep the switch from moving.
Don't know what the cut off hose is from on the seacock that's closed at the bottom of the last pic but if it's out of service, an open hose is a no no. You need to cap off the seacock with a proper fitting. At least it looks like a cut off hose.
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
You should have two bilge pumps. one is under the seat on the port side beside you sliding door. Under the seat inside the storage compartment is a false bottom. Lift that out and you should see a bilge pumped down in there. it quite a way down. The other should be in your engine room.
“Escape Plan”
Murray, KY
- dgreene
- Vessel Info: 1988 Mariner 3697
Twin Mercruiser 7.4L - Location: Fairhope, AL
- Has thanked: 15 times
- Been thanked: 9 times
Rule Industries White Standard 98B Shower Drain Kit 800 GPH 12V https://a.co/d/bi0GJtx
Doug
1988 Mariner 3697
Key of Sea
Fairhope, AL
Users browsing this forum: No registered users and 40 guests
