Running gear replacement
bestorts
Vessel Info: 2003 Carver 444 Extended Salon
Has thanked: 3 times
Postby bestorts » April 29th, 2023, 5:12 pm
I am in need of replacement prop shaft, support & rudder for a 2004 Carver 444
Any help is appreciated!
Brian
Re: Running gear replacement
Postby Viper » April 29th, 2023, 10:23 pm
Welcome aboard Brian. Do you have the old hardware? The struts and rudders might have numbers stamped on them that a prop shop can use to order new ones. Are the old ones bad enough that they need replacement or can they be repaired? It's best to replace shafts but rudders and struts can usually be fixed unless it was a really bad impact. A good prop shop that's been around for a long time might also have the specs for your model. One of the members here with the same model may also have that info, hopefully they'll chime in.
Keep us posted
Been thanked: 1111 times
Postby km1125 » April 30th, 2023, 9:02 am
And if you do find any of the specs on the originals, or what you used for a replacement, be sure to post them up here as a future member might need that info!
plittle2005
Vessel Info: 1992 Carver 350 Aft Cabin
Has thanked: 16 times
Been thanked: 37 times
Postby plittle2005 » May 1st, 2023, 6:53 am
On my '92 3307 Aft Cabin, my rudders and struts have numbers cast into them, which are visible after a bit of wire brushing. The props will usually have the diameter and pitch stamped onto the hub and perhaps a maker's ID, or possibly the last prop shop's name. But any prop shop could supply a replacement. A new shaft can be made up to match.
Phil
