1992 36 aft cabin wiring diagram
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
Thanks for any information!
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- MyPleasure
Re: 1992 36 aft cabin wiring diagram
Thanks again
- Has thanked: 603 times
I also wonder what you're referring to when writing "the part numbers for the little resistors, or whatever it is attached to the main breaker." I'm thinking this is either the reverse polarity indicator, or actual power indicators to show you have incoming A.C. If you can snap some pictures of that too, it might help.
Overall, the 120VAC wiring is pretty straightforward. I see you have a genset and I'm wondering if the "rotary switch" you refer to is the transfer switch to select shore or genset source.
Viper wrote:Source of the post Hot water heater should be on it's own breaker and clearly marked on the 120V panel. Having said that, I've also seen them hooked up to a breaker that's labeled "outlet", some chargers are hooked up like that too. Not a good labeling practice but....
On one of my boats, the charger was hooked up like that. But it was also added by the PO, not the factory, and was wired into the closest outlet, so it kinda made sense. That boat didn't have a plethora of breakers for the AC side either... only four. (One for water heater, two for 'outlets' and one for stove)
- MyPleasure
- MyPleasure
Thanks again guys!
MyPleasure wrote:Source of the post Thanks Fellas. Yes, the panel does have a dedicated breaker for the hot water, buy tracing the wiring from the hot water heater, it Seems as if the wires come from the hot water heater, to the shore/ship switch, and then goes to the hot water breaker on the panel. I’m just wondering if that is correct?
Probably NOT correct, but who knows what a previous owner might have done, and why they might have done it.
Does the "ship/shore" switch even look OEM?
I'd take some various pictures of the wiring and the setup and post them.
