Seastar leak at fittings
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
I have a Seastar hydraulic steering system. I recently had a yard install an Auto Pilot. The tech had a lot of problems stopping leaks at the fittings. I checked today, and there is still two small leaks at the fittings in the lazarette.
The setup is this. I have 3/8” hydraulic lines coming from the helm. Two of them each attach to a 3/8” tee which the bottom of the tee attaches to the hose going to the ram. The other arm (top of the tee) goes into a 600 WOG valve. All of this was originally from the manufacturer. The other end of the valve is used to attach to the 3/8” Seastar hose to the pump.
The return line from the helm feeds into its own shutoff valve, and then a hose is attached to the pump return.
He also attempted to attach a Furuno SafeHelm2 between the starboard hose and the tee fitting. That leaked, he took it off, re-attached the hose to the tee and it remains uninstalled. He replaced the 600 WOG 3/8” valve with 1000 WOG 3/8” valves.
It is now weeping at the return valve on the pump side. It is also weeping between the starboard tee and the valve.
I have moved the boat to a new yard, and plan to order new fittings and replace the work the tech “completed”. I would like to order the fittings but am not sure what tee I need. I am attaching a picture of the original tee, original 3/8” valve, and 3/8” fitting. Or, alternatively, can I just tighten the offending connections? The sealant is gasoila soft set.
Sorry for the length but hope someone here can help. Any advice would be appreciated.
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Seastar leak at fittings
Before you reef em down just remember if you use thread tape that it is possible to split fittings with excess pressure exerted. Have a close look at your fittings with a magnifying glass.
Trawler nice...
- Helmsman
bud37 wrote:Source of the post I am assuming those are the correct spec for the hoses
Trawler nice...
Thanks Bud. The 3/8” is the correct spec. The confusing thing to me is that the nipple is described as 3/8” but has a different diameter on each side. I have been unable to find the tee. I expect if I buy the Seastar fittings from one of the marine stores they will have a better shot at working.
- Been thanked: 1180 times
- Has thanked: 469 times
- Been thanked: 1765 times
Helmsman wrote:Source of the post Thanks Bud. The 3/8” is the correct spec. The confusing thing to me is that the nipple is described as 3/8” but has a different diameter on each side. I have been unable to find the tee. I expect if I buy the Seastar fittings from one of the marine stores they will have a better shot at working
See what Hans said, one side is NPT the other should be to connect to hose...combo fitting.
- Helmsman
Viper wrote:Source of the post Are you hooking up the Seastar lines with compression fittings to the TEE in the picture? The TEE looks like NPT and if that's where the Seastar compression hardware is hooking up to it's the wrong TEE.
The two original lines from the factory may not be seastar. The boat is a new boat built in Asia. The two original lines are on the tee on the left, one from the helm, the other to the ram. The new Seastar hose runs from the fitting on the right to the pump. I will post a picture of the connected set up in just a second.
- Helmsman
- Helmsman
The original picture in the first post shows the original setup. That particular tee was stripped by the tech and replaced with two fittings because he couldn’t find that tee.
I have a hydraulics guy up lined up to fix it, but would like to have all of the right, high quality fittings he might need to correct it. When you go to look for fittings, the names and types of fittings are called all kinds of different things.
