Carver 444 Prop Shaft
- Piggy3
- Vessel Info: 2003 Carver 444
- Has thanked: 12 times
- Been thanked: 2 times
Re: Carver 444 Prop Shaft
Where are you seeing the grooving?
Also, I am curious about those anodes. Do you boat in a pretty corrosive environment? Why two on the shaft? Is the strut bonded and do you have a hull anode? I've never seen anodes put on a strut like that and would think it would kill efficiency both by the direct drag as well as all the turbulence ahead of the prop.
- Piggy3
- Piggy3
A good prop shop should have no problem resizing those or are you replacing the existing ones for another reason? If you're resizing the existing ones, have them checked to ensure they're straight first. If they aren't, cut new ones instead of straightening and cutting the old ones. Straightening can sometimes result in them bouncing back to their bent position over time. While they're off, send your props in to get checked too, that shouldn't cost you anything unless they report needing some tuning. While you're under there, check to ensure your struts are straight and not bent. If they're bent, take them to the prop shop too. Check to ensure the strut bearings are in good shape, if they aren't, now's the time to replace them.
Before you pull the shafts out, check their alignment through the struts and stern tubes through the hull to ensure the shafts are centered through each of them. This will give you an idea if you're in for additional work after you get the shafts back. If they aren't centered, you'll need to do engine alignments and or strut alignments. That final work though should only be done with what you know are straight shafts, and final engine alignments should be done after she's back in the water for a day or so but you can check and get things close while she's on land. In the end, you have a max of .003" to work with all around between the tranny flange and shaft coupler.
If you don't currently have them but were thinking about dripless shaft logs, now's the time to pull the trigger if they're in the budget.
Can you tell I'm trying to get you to BOAT (Break Out Another (Ten) Thousand)
- Piggy3
Thanks again
