454xl leaking fuel
- Thelma Jean I
- Vessel Info: '95' Carver Santego 380
- Has thanked: 21 times
454xl leaking fuel
- Has thanked: 597 times
- Been thanked: 1275 times
Re: 454xl leaking fuel
Is the leak coming thru the threads....looks like it but real hard to tell from the pic, a bit dark. Sometimes lines get bumped and it loosens the fittings. Good luck and be careful with fuel leaks, they can be extremely dangerous.
- Thelma Jean I
- Been thanked: 601 times
The leaks were most likely on the pressure side of the fuel system. So once the pressure is relieved the leaks will stop and you will not see any leaks overnight.
So please make sure you look again when the system is under pressure. make sure to ventilate well and have extinguishers handy just in case.
Best wishes!
- Thelma Jean I
Be sure to get matching fittings when you reassemble.
- Thelma Jean I
Users browsing this forum: No registered users and 7 guests
