Removal of shaft seal ASAP- 396 Aft Cabin
tgebler
Vessel Info: 2000 396 AC
Has thanked: 5 times
Been thanked: 29 times
Postby tgebler » May 16th, 2023, 10:15 am
My mechanic is replacing the starboard shaft seal but can't get the old one off the shaft. I need some recommendations ASAP
Re: Removal of shaft seal ASAP- 396 Aft Cabin
Postby Viper » May 16th, 2023, 7:26 pm
Can you explain exactly what you mean by "shaft seal." Are you talking about a seal from a dripless shaft log assembly? Confusing because if that's the case it shouldn't be a problem to remove the seal unless the assembly has melted. Can you post a picture of the part you're talking about?
tgebler
Postby tgebler » May 17th, 2023, 9:59 am
My mechanic removed the shaft seal after much effort and finally applying heat. Thanks for the interest.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Postby KyleR » May 18th, 2023, 9:33 am
What did he apply heat to? Was it the seal that was stuck or the coupler? Heat to the coupler makes sense, but I can't figure out heating the seal. :confused: Thanks!
MV Verity
2002 Carver 396
tgebler
Postby tgebler » May 18th, 2023, 6:45 pm
Coupler
Postby Viper » May 18th, 2023, 7:49 pm
So is it that he couldn't remove the seal or couldn't remove the coupler?
KyleR
2002 Carver 396
Postby KyleR » May 18th, 2023, 8:11 pm
Gotcha - thanks for the follow-up! As a side question - do you know (or can you ask your mechanic) what size socket was needed to remove the nylock nut on the shaft that held the coupler on?
I've researched and can't get a definite answer. 1 1/2" thin-wall socket was recommended but for a different model boat (but still had a 2" shaft). I also have a 396 (2002 model year) so you would probably have the best info! :-D
Any help would be greatly appreciated as I am about to tackle this same project. Thanks again!!
MV Verity
2002 Carver 396
Users browsing this forum: No registered users and 53 guests
