Vacu Flush switch
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Vacu Flush switch
Postby pepmyster » May 18th, 2023, 8:05 pm
Hi all!!!!!!!! I have a 360 Sports Sedan and heard that some people have a "silent" switch ( basically an on and off switch) for the head power. If you do, where would it be installed. I would like to install one so that when we are not on the boat, we don't have to go to the engine compartment to turn off the power. Thanks in advance!!!!!!!!!!!!!!!11
Re: Vacu Flush switch
Postby km1125 » May 18th, 2023, 8:48 pm
Don't you have a breaker in the DC panel for those?
Postby Midnightsun » May 18th, 2023, 9:29 pm
Mine is right with the light and fan switch in each head. If you have one it will be labeled vacu flush run/sleep. Basically an on off switch conveniently located.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » May 18th, 2023, 10:17 pm
pepmyster wrote:Source of the post Hi all!!!!!!!! I have a 360 Sports Sedan and heard that some people have a "silent" switch ( basically an on and off switch) for the head power. If you do, where would it be installed. I would like to install one so that when we are not on the boat, we don't have to go to the engine compartment to turn off the power. Thanks in advance!!!!!!!!!!!!!!!11
If you have a switch, and I can’t imagine you not having one, it will be right there next to the head and very obvious.
And why do you have to go in the engine room to turn it off? The head should have a breaker switch on your 12 volt panel.
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » May 19th, 2023, 6:35 am
Thanks for all the replies! The only breaker I have for the head is in the breaker panel in the front section of the engine compartment. None in the dc panel....none in the head area....
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » May 19th, 2023, 6:48 am
Not mine but the same. Only light and fan switch.. Only breaker in dc panel for the head it's for the forward head fan.
Postby g36 » May 19th, 2023, 11:06 am
Wow that's pretty inconvenient. All you have to do is put a switch inline to the pump power but running it into the head might be a challenge. I don't have any idea about your layout. But I would install one somewhere that would be easy enough to get to even if its not ideally by the head.
Postby Viper » May 19th, 2023, 12:36 pm
Have you checked all the cupboards in the head, behind curtain, etc.? I've seen them in some pretty weird places.
Postby bud37 » May 19th, 2023, 12:42 pm
I think considering....what if you have to use the head at night......you would want a switch in the head or very close to it. Also , have a real good look, they almost always have an easily accessible breaker without going in the engine compartment....
Hopefully, someone with the same model as yours can chime in.
Postby Midnightsun » May 19th, 2023, 12:46 pm
I really never use the switch. If the head is cycling there is a leak somewhere. Mine never cycles. That being said, my forward head is not building vacuum like it should so I actually used the switch to turn it off yesterday until I change the duckbills that is. Probably going to get at her later today.
Users browsing this forum: No registered users and 37 guests
