Vacuflush Preventative Maintenance
I watched a few videos from however they only recommend changing the duck bills every 3-4 years and every year on a live aboard. Sounds a little to preventative if you ask me.
I am thinking 5 years for the duck bills and 7 for the bellows? Your thoughts?
My original bellows lasted 16 years just for reference. Going to do the rear bellows and duck bills when I get the parts even though she works fine.
- Been thanked: 1111 times
Re: Vacuflush Preventative Maintenance
I think having the spare parts on hand is a bigger issue, as it usually doesn't take that long to repair. The bigger issue is trying to locate and get the parts, because they're usually much harder to get when something comes up unexpected. (one of the corollaries to Murphy's Law).
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 137 times
But, it does seem like the original bellows from years ago seem to hold up so much better! (surprise, surprise)
I have read multiple accounts of the original bellows lasting 10-15+ years, whereas the more recently made ones seem to fail sooner. For me, I now just keep a spare bellows and 4 duck bills on board. Since longevity is questionable my plan is just to "run to failure" then replace. YMMV
2002 Carver 396
- Been thanked: 654 times
- Has thanked: 602 times
- Been thanked: 1310 times
- Bakoboat
- Vessel Info: 456 carver 2000
Will update when I get a reply.
I have a friend with a VacuFlush and he was having the problem with the breaker tripping frequently and the motor not working. It would start to pump, them jamb and trip the breaker. I had him reverse the leads to have the motor run backwards (but it still pumps vacuum normally) and that got him through until he was able to get a new motor and install it. He gave me the old motor and I opened it up to see what was going on. I suspected there was excess play in the gear mechanism that runs the cam and thought I could resolve that, but that end looked just fine. It was actually a failed bearing on the brush end of the motor. That bearing can be replaced.
I wonder if that's the common failure on these.
- KyleR
2002 Carver 396
I rebuilt my vacu flush last summer, this spring the bellows was split open at one of the seams. I have a request in to Dometic for replacement. I suspect a manufacturing flaw because of the way it split apart.
Please do - as this exact same scenario happened to me. It lasted maybe three months before it split. The current one has been going for six months, but after the early failure of the first replacement I get worried every time someone flushes!!
2002 Carver 396
km1125 wrote:Source of the post Curious question for any of you guys with VacuFlush systems... Did you ever have a motor fail? What were the symptoms? Did you take the old motor apart to see what actually failed? What did you do with the old motor?
Thanks for posting, good to know the bearing can be replaced. May come in handy one day.
- Bakoboat
Hope this helps.
