Replaced exhaust risers
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Replaced exhaust risers
Good job Tony. Aren't boats fun?
- tonyiiiafl
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 52 times
- Been thanked: 27 times
dgreene
- Vessel Info: 1988 Mariner 3697
Twin Mercruiser 7.4L - Location: Fairhope, AL
- Has thanked: 15 times
- Been thanked: 9 times
Doug
1988 Mariner 3697
Key of Sea
Fairhope, AL
- tonyiiiafl
- tonyiiiafl
With closed cooling, what do you all run for thermostats? 160? With 160 it gets up to around 170 or so, 185 when running it hard.
Thank you!
Tony
- Has thanked: 78 times
- Been thanked: 1093 times
160F is pretty common in closed cooling. Some can run higher temps, but note that if you run higher than the engine was designed you may have to adjust things like spark timing to compensate.
- tonyiiiafl
- Has thanked: 598 times
- Been thanked: 1281 times
Now in my experience engines that get quite a lot hotter when just run mildly hard are having a problem with heat exchanger efficiency. Because you are seeing salt you have to keep the temps down in the exchanger as mentioned or the salt/minerals will separate and adhere to the exchanger surfaces thereby making things worse and the spiral starts. Perhaps it is time for a flush......
Actually the warmer you can run an engine within reason the more efficient the heads will be, but with marine engines there is a caveat if you boat in salt/brackish water. .....my opinion anyway.
