Marine Air Sys VRP16K
- Cork the Whine
- Vessel Info: 1997, 355AC
- Has thanked: 20 times
- Been thanked: 10 times
I have a 97' 355AC and yesterday our salon and V berth air conditioner stopped working. What I mean by that is that the water pump and compressor stopped running. The fan on the AC unit will interestingly will run. I know the water pump works because it works for the aft cabin airconditioner. Also when the aft cabin AC unit runs, theres good water flow out of hte boat and the sea strainer is clean.
Does any one have any experience troubleshooting these systems? It's a Marine Air, VRP16K, 16,000btu unit. I'm reasonably handy, but AC is not my forte. Any guidance or troublshooting assistance would be appreciated. Wondering if maybe caps failed?
Cheers!
John
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Marine Air Sys VRP16K
- Has thanked: 78 times
- Been thanked: 1093 times
On some units there is a reset switch right on the unit, and it's for a high-pressure fault. Once it's tripped you need to manually reset it to get the compressor working again (after you've found and resolved what was the cause of the high pressure condition!).
- Cork the Whine
km1125 wrote:Do you have GOOD water flow out BOTH ports when the water pump is running? The 16kBTU unit would (probably) require more flow than your aft unit (which I'm just guessing is a 12kBTU unit).
I've got great flow out of both ports when the aft cabin unit runs. Any idea where the reset switch "may" be? Is it actually on the unit itself or in one of hte control panels?
- Been thanked: 646 times
g36 wrote:Source of the post This should be it if you dont...https://www.google.com/url?sa=t&source= ... jYmh66oAZu
If that's the right manual, then his unit does not have the manual reset. It will automatically reset once it cools down.
- Cork the Whine
- Cork the Whine
It's this thing in the circuit...
