Raw water pump fittings
- Bilgewater
- Vessel Info: 78 Carver 3396 Mariner
- Has thanked: 2 times
Re: Raw water pump fittings
Why do you need to replace the pump? You can do minor and major rebuilds on those pumps and it's not that hard to do if you have access to a press somewhere.
Also, if you do have to replace it, then think about "upgrading" to a crank-mounted pump. If you have plenty of room in front of the engine (not all have this!) then it's much easier to replace the impeller when it needs to be done, and it eliminates a belt from the system. You'd have to replace a couple hoses (to and from the pump) too, but it might be worth it in some applications.
