What size nut is this?
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 143 times
- Been thanked: 134 times
Based on the attached drawings, it looks like the nut (Item 7) that holds the coupler on the shaft is a 2 1/4" nut, but I just want to make sure I'm reading it correctly. If you look at all the other items, they use the "inch marks" with the dimensions, but not on this part for some reason.
I've also heard that it is a nyloc nut and requires a thin-wall socket to fit inside the coupler. I wasn't sure what all the nomenclature for "CSL 2-1/4 SHT" meant.
Has anyone done this job and/or have any other advice? Thanks in advance!
2002 Carver 396
- Has thanked: 469 times
- Been thanked: 1765 times
Re: What size nut is this?
Yes it will be a nyloc type nut and you will need a thin walled socket for it. In a pinch when I couldn't find the right thinned walled socket, I've taken a regular one and had a prop shop turn it to the right thickness. I've grinded them down myself too. Some prop shops will also carry these sockets but a good tool supplier shouldn't have an issue getting one for you. BTW, I've also had to grind down a thin walled socket, so don't be surprised if that's what you run into.
- Has thanked: 598 times
- Been thanked: 1281 times
For what its worth, I have ground down sockets many times with a bench grinder, especially plug sockets, they are hard so don't overheat them while doing it.....good luck with your project.
- Has thanked: 78 times
- Been thanked: 1093 times
Viper wrote:Source of the post CSL is a self clinching nut. Not sure about SHT but I suspect it may be a metallurgy standard/term.
I thought CSL was for a castellated nut, which would make sense if it has that cotter pin that the parts list shows.
But I wouldn't bet the farm on that being right either.
- KyleR
2002 Carver 396
2002 Carver 396
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
- KyleR
2002 Carver 396
I could not get the nut off with a 3/4” bar and a pipe over it that was about 5’ long.
Yikes!
Here's a pic of the cotter pin location. Does this look like the same configuration? Also, did yours have a 2" shaft? Do you happen to have any pics of your setup? Thanks for taking the time to reply!2002 Carver 396
I guess it will all depend on whether the couplings have been worked on since new boat delivery and who has done what since.
But... seeing the corrosion on the outside of the coupling, who knows what you might run into trying to get the old one off.
Users browsing this forum: Google [Bot] and 36 guests
