Salt Water in Galley Bilge
- Morningstar4207
- Vessel Info: 1986 4207 Carver Californian
- Has thanked: 19 times
- Been thanked: 1111 times
Re: Salt Water in Galley Bilge
Sounds like you have a couple issues!! I would check EVERY through-hull and seacock, both shaft seals and both rudder packings. I'd also check any exhaust hoses to see if they might have been compromised by a critter or two. 300 gallons in a few hours is a VERY serious leak!!
Not sure on that boat how (or even IF) the bilge is compartmented to keep water on one section but not another. Other boats of similar vintage would have had some bulkheads but depending on the design they might have limber holes though them to allow water passage.
I'm curious when you say the "hard-wired breaker switch on the electrical panel". Are you talking about the DC breaker panel
or the helm? If you're referring to the breaker panel, is that "hard wired switch" really just the breaker for the bilge pump? There should be two... one for the automatic circuit and one for the manual circuit. There should be manual switches for each bilge pump at each helm. Post up some pictures if you want some additional clarification on this.
- Has thanked: 602 times
- Been thanked: 1310 times
I would dry the bilge and keep watch, constantly check all bilge areas with a nice bright light to see where the water is coming from, might take some time but the alternative is sinking at the dock .......a big leak should be fairly obvious.
- Morningstar4207
Thank you so much, for reminding me that we have bilge switches at both helms too! The lower helm has the automatic bilge switches and they were turned off, maybe our mechanics did that when it was on the hard? We normally kept those on and didn't even check them until you brought them up again. I just flipped them on just now and the galley pump engaged.
Now, we can sleep easier until we find this leak.
- Morningstar4207
Morningstar4207 wrote:Source of the post km1125, thanks so much for your quick response and for welcoming us aboard! Our bilges are compartmented. I am talking about the DC breaker panel, the switch for all my bilges is on that panel but we've always kept them turned off there.
Unless something was done by a prior owner that changed things, you'd want to leave the breakers on the D.C. panel turned on ALL the time except when the boat goes into storage. This would be especially important for things like bilge pumps. Typically at the helm(s) the switch will toggle between "auto" and "manual", so you can activate the bilge pumps manually if you choose, but then put them back in to "auto" mode for normal operation. "Auto" will only work though, if you have good float switches and there is power to that circuit (which is usually supplied by a different breaker either in the panel or near the battery switch).
- Morningstar4207
We found the leaks while checking the packing on the rudders. All 40 screws on our trim tabs were either missing or falling out. We didn't get to see the bottom job before it went back in the water & the marina that did our bottom did not notice.- km1125
Were you able to get new screws in there, or did you do something to stop the leak until you can permanently resolve it?
- Morningstar4207
