Hynautic Steering Purge Valve Needed
- Merkinbrumsky
- Vessel Info: 1985 Carver Voyager
- Has thanked: 53 times
- Been thanked: 38 times
- Has thanked: 603 times
Re: Hynautic Steering Purge Valve Needed
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
- Merkinbrumsky
bud37 wrote:Looks like you may be able to easy out the bolt remnants.....may be worth a try.
I was thinking that too initially. That bolt that’s sheered off appears to have a bleeder line inside of it though. I’ve spoken to several tech’s over the phone and been told that this is not a simple solution. The valve has to be set it for 550psi or so. Any replacement would have to be calibrated on a bench first. Also I was told it has to be installed from the inside of the reservoir, which means removing it. If I can find an old reservoir I could just swap the purge valves out though. Another option would be to plumb in a stand alone purge which I have seen a few nos online but they are pricey. Another tech told me it is just an air compressor dump valve but that goes against what at least 3 others have told me. Worst case I can remove it and ship to Florida for a rebuild but hoping to just find a replacement and swap out in the winter if possible as our season up here is so short.May have to scour the scrap heap and see what I can find. I was hoping a member would have a lead on an old reservoir. Does not have to be the exact one, just had to have the same purge.
- Phrancus
- Contact:
So fill it all up, fill the reservoir and after that you put pressure on it with a simple bycicle pump.
The bleeding procedure that matters more is the turning all the way both ways (pump the oil through the system) and then bleed it at the highest point(s).
Read forementioned documents and think about the principle, I really don't believe that you need special bleeding bolts for this.
- Phrancus
- Contact:
viewtopic.php?f=7&t=7469&p=58690&hilit=hynautic#p58690
and the one with the files I can't find right now but I remember posting them in a .zip file.
EDIT: found it: viewtopic.php?f=7&t=6791&p=53376&hilit=hynautic#p53376
- Merkinbrumsky
Phrancus wrote:Source of the post If I remember correctly that system is not so complicated. Bleeding nicely and like designed is through a special bolt or tap. In real life you can often simply loosen a line. Spills but that doesn't matter as it's you own boat and you do the cleaning, not a paid mechanic.
Thanks for the info. So….if needed I could simply loosen off the P & S hoses one at at a time at the highest helm and do the 60 turns each way, catching any spillage at the helm while making sure the reservoir is topped up if I am in need of a purge?
- Phrancus
- Contact:
There was/is some material on youtube on how to refurbish the wheel pumps/hubs and that also explained the workings. If I remember correctly, the pressure keeps air out but does not do anything in power assistance. Power assistance comes from the pump on the engine connected to a hydraulic cylinder at the rudder linkage.
I found it a bit elaborate and impractical to check the pressure and all. Where other systems (vetus?) simply allow all air to go up. Bleed/fill up on top and done. But I may be wrong on that.
- Merkinbrumsky
- DvB
- Vessel Info: 1986 Carver 3207 Aft Cabin, twin 260 Mercruisers
- Has thanked: 2 times
- Been thanked: 7 times
Since I was just installing the fly bridge pump I rebuilt, I only bleed the port and starboard line. I did do the 6o turn thing and both helm stations.
DvB
