Rule A Matic Float Switch Garbage
Bottom line is the switch internally seems to become intermittent. They seem to last about 4 years or so and they are awfully proud of their product at around $100 cad once delivered and taxes are paid. Last time I replaced it with their 40a model assuming it would last longer but that did not happen. This is the one that is installed in there like the original. https://www.amazon.ca/Rule-40A-Matic-Switch-Moisture/dp/B000O8DA0K/ref=asc_df_B000O8DA0K/?tag=googleshopc0c-20&linkCode=df0&hvadid=293019546650&hvpos=&hvnetw=g&hvrand=9475531068294994592&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9000603&hvtargid=pla-574196784892&psc=1
I am going cheap Chinese as the ratings are very high and they are so much cheaper. Bought 2 just to have a quick change spare if required. will only be able to use 1 screw down hole but that is more than enough. Have a feeling these will last much longer at 1/5th the price. https://www.amazon.ca/gp/product/B083FQK2WP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Rule A Matic Float Switch Garbage
https://www.amazon.ca/sspa/click?ie=UTF ... %26psc%3D1
- Has thanked: 603 times
Could the soap residue be causing an issue with the float ?.... Well I guess we can consider where these fine products come from.
I have had aquariums almost all my teen/adult life. I put away my last one a few months back. Had a home made auto water top off with one 2$ float switch in SALT water. This setup triggered several times a day 24/7 and in 11 years, never an issue. This was the float.
https://www.aliexpress.com/item/1005005 ... 1687633073
Seriously considering installing one like this through the shower sump cover with a small relay to handle the current. Bet you I would never touch it again.
Looked the the auto float switch pump you pointed to however the flow and hose size would be too big to fit in mine. Did find this one though that would be a good fit assuming its not too tall. https://www.amazon.ca/AURELIO-TECH-Automatic-Submersible-750GPH/dp/B083FQCHNZ/ref=sr_1_29?crid=1DBYW7JNZZ6NX&keywords=marine%2Bshower%2Bsump%2Bpump&qid=1687634294&s=sports&sprefix=marine%2Bshower%2Bsump%2Bpump%2Csporting%2C116&sr=1-29&th=1
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
This float switch will bolt right into an existing hole in the shower sump. https://www.amazon.ca/gp/product/B083FQK2WP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
This pump will snap right into the existing Rule 800 base however it is slightly taller so it interferes with the cover. Easily solved by using a 2" hole cup saw and opening the cover right over the motor. Can be left like this or just put some duct tape over it if you want to seal it. These covers are not water tight and do have open holes where the wiring passes through. https://www.amazon.ca/gp/product/B004LR7H7C/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Had a spare 98a box that I have already salvaged the pump and switch from so I experimented on it for fitment at home with the parts listed above. The float needs to be turned around as shown as there is interference from the plastic screen and float movement if turned the other way. The blue base of the pump is the original Rule base, Even the location of the pump outlet is identical to the Rule and you can see the original Rule transparent hose with internal check valve slips right on.
Hopefully these components will outlast the original ones as they did not fare very well. The good news is these replacement parts are readily available usually next day through Amazon.
