Fuel issue with port engine
- Gary Rose
- Vessel Info: 2000 356 carver aft
- Has thanked: 5 times
- Been thanked: 3 times
- Has thanked: 603 times
Re: Fuel issue with port engine
Does this happen at the dock out of gear/in neutral?
Did you try running the engine with the deck fill fuel cap off in case the tank vent is clogged?
Have you tried hooking up a portable fuel tank directly to the engine?
- Gary Rose
Gary Rose wrote:Source of the post Blew out vent tube already and no I haven’t had the eng scanned yet, waiting on tech to get back to me. Also swapped fuel hoses from the port to the starboard tank and no different and the starboard eng runs fine.
There are a number of things that work together to allow the engine to run smoothly, any one of them failing can interfere, you need the scan........try to get a recording of the engine running to failure, that should help in the diagnosis, also can eliminate the throwing parts at it and hoping.....good luck with your tech, hopefully he has the program and laptop.
Users browsing this forum: 96Voyager and 22 guests
