12v DC tripping on panel
- smullis1961
- Vessel Info: 36 Ft 1988 Carver Aft Cabin
- Been thanked: 2 times
- smullis1961
Re: 12v DC tripping on panel
On the 12V side, that second main just powers all the breakers on that line. Shut ALL those breakers off and see if the main holds. If it does, then start turning the individual breakers on one at a time.
If the main DOES NOT hold, then open the panel (there's a key above it that unlocks it, and the whole panel hinges down) and see if there's any wiring amiss on that second row. You could have something shorted there. Otherwise, it might just be a bad breaker in that "2nd row main" position.
smullis1961 wrote:Source of the post In addition, I have noticed now that when you flush the heads(electric) the main breaker on the 12V DC trips immediately.
If that's the ONLY time it trips, then I'd explore if there's an issue with the heads drawing too much current. There are two separate heads... do they both cause this or just one. There should be a separate breaker for each head too, so you can isolate them from the main.
- smullis1961
- smullis1961
- Has thanked: 602 times
- smullis1961
smullis1961 wrote:Source of the post I turned off both 12v main breakers, and then turned on the 2nd main 12v and it still tripped
If it trips with ALL the other breakers IN THAT ROW turned off, then it's either a bad breaker or a short behind the panel.
