Too many problems!
- Jcamp
- Vessel Info: 2000 Carver 380
- Has thanked: 4 times
Too many problems!
So I guess I’m wondering what I should do as far as these engines go. It seems that it’s going to be pretty difficult to find remanufactured engines from a reliable source at least that’s what Mike Mechanic says. I know I can’t buy them new, so I’m wondering if I should go to a secondary source to get remanufactured 7.4 L MPI magnums or go carbureted or swap everything out and convert it to a diesel. I really like the idea of converting it to a diesel but I’m not exactly sure what the differences are between a Carver that was a diesel as opposed to when that is a gas. In other words will I need to change the struts? Do I need to change shaft sizes? Do I need to change the transmissions etc. I’m hoping there’s someone in this forum that owns a late 90s early 2000s Carver 380 that came with diesels from the factory as I would like to pick their brain and see exactly what I would need to do to convert it and if it’s even worth it. Again, I do apologize for, the long winded post , Jeff
Re: Too many problems!
What actually happened to the engine? You can typically replace the short or long block to get an existing engine back in operation. I would not go back to carbs on a boat that was already set up for fuel injection.
You state you "thought it had 330HP" and it was "advertised with 330HP", but what is actually in it. Sounds like Merc big blocks which typically would be around 330HP.
- Jcamp
- Hoplite808
- Vessel Info: 1988 Carver 3227 Convertible
- Has thanked: 1 time
- Been thanked: 8 times
- Jcamp
Did the engine throw a rod or just stop running? Was wondering what made you pull the engine?
