2807 Riviera blower
- Asbury509
- Vessel Info: 1986 Carver 28 foot, model 2807 Riviera Aft cabin.3
2807 Riviera blower
Re: 2807 Riviera blower
Unless you have an inverter or generator, none of the 120vac outlets would have worked until you plugged into shorepower. some of those interior lights might be "120VAC only" too.
With that vintage vessel, you should have circuit breakers for things like the engine room blowers. Might even have a couple "main" breakers that also supply power to a whole bank of individual breakers.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
- Asbury615
- Vessel Info: 1986 Carver 2807 Riviara
Asbury615 wrote:Source of the post Thanks for your input, all systems 12v worked fine until the blower shutdown. There is an inverter for the 12v system. When you say “breakers” there is a panel that has switches for various onboard systems, do these represent “breakers” or would the actual breakers be behind this panel?
That panel is likely breakers, and for your model there might be a couple "main" breakers that each feeds a row of individual breakers. Post up a pic if you want a more detailed response.
- Has thanked: 603 times
Welcome to the forum.....
The reality is that your boat has been around for a long time.....in that case you are never sure what someone before has done. The blower may have just given up, maybe it was replaced at some point and there is an added fuse somewhere...all things have a life span...some searching and investigating will probably be in order here.
Remember try not to confuse the 12 volt ( boat ) side and the 120 volt ( shore power) side.
There is some good advice above.
