-1987 Carver 4207 Navigation light bulb size (LED)?
- steve&tammy
- Vessel Info: 1987 Carver 4207
- Been thanked: 9 times
Ok, so I'm heading back down to the lake this weekend and wanted to order replacement LED equivalent bulbs for both navigation lights as well as the stern transom light. They all, at least appear to be, original to the boat.
Any help on the bulb size/style would be super helpful prior to me leaving so that I can order them asap.
Thanks in advance!
- Been thanked: 654 times
Re: -1987 Carver 4207 Navigation light bulb size (LED)?
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Just google marine LED bulbs.
Not as big of an issue with the stern light, mast light or the anchor light, but on these there are also issues with the replacement bulb and the focus of the lens. The original light anticipated a light source from a pretty small filament, centered in the lens. The replacement LED may not have a single "bulb" to replace the filament, but a handful of smaller LEDs to get the necessary brightness. These are spread out and no longer at the focal point of the lens, which means the light won't be concentrated towards the horizon like the original light.
That all said, you might want to just consider replacing the whole assembly with an LED model. They are not really all that expensive, nor that hard to replace.
- buster53
- steve&tammy
Now we're moving on to the interior.
BTW, absolutely stellar point about the Kelvin temp of the bulb and how that affects the overall color output. I'm assuming you're correct that "warm white" (2500-3k) should do ok.
Was more specifically asking if anyone of you actually KNOW the LED equivalent? As mentioned in my OP, I was hoping someone knew the bulb size...I'm guessing it's an 1157?
Either way, we're heading down Friday and if I could find out the correct size, I'd just assume order it now to get it to my home prior to our trip...
Thanks again!
I think all the 1157 bulbs were also a dual filament and used a bayonet base with staggered pins so it could only be inserted one way. You won't find those on boats (or I haven't seen them). There are bulbs used which are SIMILAR, but the two pins at the bottom connect directly to the filament, rather than one side of the filament using the metallic base of the bulb as a contact. And the pins aren't staggered so they can be inserted either way.
Users browsing this forum: Beachlovers and 23 guests
