1985 26 santa cruz
0613bruce
Vessel Info: 1985 santa cruz 26
Has thanked: 5 times
1985 26 santa cruz
Postby 0613bruce » August 1st, 2023, 1:48 pm
just picked up an decent 1985 Santa Cruz 26.
seems mechanically sound. Needs a good cleaning.
Been sitting for a while, so i'm sure i'll find some gremlins:)
Bruce :captain: :beergood:
0613bruce
Re: 1985 26 santa cruz
Postby 0613bruce » August 1st, 2023, 1:53 pm
Postby km1125 » August 1st, 2023, 3:07 pm
Congrats on the new-to-you boat!!!
New Brunswick is a pretty cool place... lots of good scenery! What areas are you going to be boating in?
0613bruce
Postby 0613bruce » August 1st, 2023, 3:14 pm
Mostly Grand Lake, but also the Saint John River system from Fredericton to Saint John.
Postby Viper » August 1st, 2023, 4:13 pm
Welcome aboard Bruce
0613bruce
Postby 0613bruce » August 2nd, 2023, 8:20 am
any balsa wood in the hull structure of these boats, or just in ceilings?
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » August 2nd, 2023, 9:18 am
Welcome aboard. Typically, the hull below water line is solid. About 6" above the waterline, there is a balsa core. I am not 100% sure on the 85's. A moisture meter would be recommended to determine any intrusion. Good luck. 8-) er
Cooler By The Lake
Been thanked: 490 times
Postby waybomb » August 2nd, 2023, 2:15 pm
Welcome aboard!
0613bruce
Postby 0613bruce » August 15th, 2023, 11:34 am
so, turns out it's a 1981 santa cruz. no big deal, still an old boat either way.
fuel tank is leaking, and needs to come out. seems like there might be room enough to remove it without cutting deck or removing engine. anyone ever take this on in one of these boats? probably going to replace with a plastic tank.
bruce :captain: :beergood:
Postby km1125 » August 15th, 2023, 11:58 am
If you haven't already, you might want to peruse this thread:
viewtopic.php?f=13&t=1228
He took an '80 vintage of that model and did extensive renovation. You're not anticipating anything near that complicated, but some of the pics might give you some ideas and some inspiration.
Users browsing this forum: No registered users and 46 guests
