1987 Carver 3697 Mariner Props
- carver3697'87
- Vessel Info: 1987 Carver 3697 Mariner
- Has thanked: 1 time
This sunday I hit something (probably a rock) and damaged a prop based on vibration after the hit. I will go under the boat in the next week and check the shaft, rudders,etc. and see what props are on the boat and make sure nothing else got hurt. I am interested in the stock proppeller size pitch and bore to see if I can find a spare set. What were the "stock" Props? Thanks!
Re: 1987 Carver 3697 Mariner Props
The most important thing is the shaft size (and you can find that out from INSIDE the boat). If I had to guess it's say 1 3/8", but really needs to be confirmed.
You could get a spare set of props that are marginally larger or smaller and still get great performance out of the boat, although not ideal. What that buys you though is the ability to get back on the water ASAP while the main set are reconditioned. I had bought a set from an old Sea Ray that were 2" smaller in pitch and three blade instead of four, and it only cost $300 for the PAIR. Both times when I used them I ended up leaving them on the boat for the rest of the season and changed them back to the originals over the winter break. I lost a little bit of speed at cruise RPM but not enough to really make a difference in the usage of the boat, but I was able to use it IMMEDIATELY, as it just took a couple hours o haul the boat and swap the props. That also makes the assumption that you didn't hit something so hard as to bend the shafts or damage the struts.
- carver3697'87
- dgreene
- Vessel Info: 1988 Mariner 3697
Twin Mercruiser 7.4L - Location: Fairhope, AL
- Has thanked: 15 times
- Been thanked: 9 times
Doug
1988 Mariner 3697
Key of Sea
Fairhope, AL
- carver3697'87
Post up some pics when you get them off!
- carver3697'87
- Been thanked: 490 times
Users browsing this forum: sdsurf and 33 guests
