Most economical cruising speed
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
Re: Most economical cruising speed
As far as the Carver 36 aft cabin we currently have, with the big blocks, I guess that it’s going to be cruising at hull speed for us. At almost $10 for a US gallon of gas here in BC, slower is better!
Has anyone ever installed the Holley fuel injection on their engines? Just wondering what the difference would be in fuel consumption over the Edelbrock carburetors on the engines now?
Thanks again fellas!
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- MyPleasure
- Rocketman
- Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
- Been thanked: 24 times
If you want to run on - my experience is that you need to get up on plane a little more so your not dragging as much.
Typically this ends up being about 3/4 throttle to get the boat really up on plane and running efficiently.
With your fuel flow meters you should be able to do some trials and find your sweet spot for hull speed and on plane.
MyPleasure wrote:Source of the post
.... Has anyone ever installed the Holley fuel injection on their engines? Just wondering what the difference would be in fuel consumption over the Edelbrock carburetors on the engines now?
Going to fuel injection won't really make the engines more efficient over a carb, unless your carb is having issues and not operating correctly. It's much easier and cheaper just to fix the carbs.
Fuel injection can be more efficient, but you need to add a lot of other features to do that other than just injecting the fuel. You need to add a closed-loop mechanism (air/fuel ratio sensors in the exhaust, normally O2 sensors) and need to optimize the timing and the fuel amounts for all speed/load ratios more accurately. Normally on marine engines they run a little richer and with a little less spark advance so they are more tolerant of all kinds of issues (like non-optimum fuel) so they don't destroy themselves under load.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- MyPleasure
- Has thanked: 603 times
Hopefully those carbs you have are the marine versions.
- Seaplane Steve
- Vessel Info: 1990 Carver 3608
- Has thanked: 4 times
- Been thanked: 2 times
We just did our first fueling. We were not keeping great track of run times for the first part of these tanks, but we are now. We typically cruise around 1500-1900RPM, guesstimate we used about 150gal in 15-18 hours of cruising. Seems to match the flow numbers provided earlier.
It has been fun when we get new people out on the boat to show them what planning looks like. Wide open we hit about 22kts at just over 4,000RPM. Come back to about 2800RPM where I have been told the extra two bbls close and we are down to about 14kts and start to need some bow down trim to keep the ride comfortable.
- kgarguilo
- Vessel Info: 1999 Carver 406
- Has thanked: 197 times
- Been thanked: 55 times
- Gallons per hour obtained underway on Diacom software
RPM / GPH per Engine /Total GPH / MPH GPS
1050 - /1.57 /3.14 /7.26
2000 - /4.54 /9.08 /10.00
2776 - /9.46 /18.92 /12.5
3449 - /14.95 /29.90 /20.7
3950 - /21.14 /42.28 /22.5
1999 Carver 406
kgarguilo wrote:Source of the post I almost forgot to post the MPH until I just saw your post.Gallons per hour obtained underway on Diacom software
There was probably a spot between 2776 and 3449 RPM where the fuel economy would have popped up a little higher. It doesn't look like you were all the way on plane at 2776, or needed a little tab there to help. The fuel economy is lower than it was at 3449.
