Battery voltage loss
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Battery voltage loss
- pepmyster
8.1 Volvo Penta
- Has thanked: 603 times
- pepmyster
8.1 Volvo Penta
I'm assuming all 4 batteries are in the same bank and they are ALL wired in parallel correct?pepmyster wrote:Source of the post.... We have 4 house batteries. All connected with 2 gauge on the rear 3 which are in parallel......
You're assuming because they're all in the same bank and the same batteries that they're all going to degrade at the same rate but that's not the case, there's just too many variables affecting performance and longevity for them to be consistent with one another over time. That's why it's common for just one in the bank to fail and bring the rest of them down with it.pepmyster wrote:Source of the post....If I was to do an amp test on just the rear 3, I get an average of 1450 cca. The 3 are 750 cca rated deep cycle(flooded). If I do the same test from the front main house battery, I get 1100 cca . So 4 house, all excellent shape, all 750 cca, and I get only this.....
Are all the batteries in the bank the exact same spec and bought at the same time? Are the fluid levels checked periodically and are their levels relatively consistent throughout? Is the area of the 3 any different in ambient temperature than the area of the single battery? Is the charger's output temperature compensated?
Are your charger outputs running through an isolator? It shouldn't be if it has enough output legs (banks) of its own.
- pepmyster
8.1 Volvo Penta
Seems to me I remember you installing a battery monitor with a shunt when we were discussing your battery banks and solar panels a while back........that monitor should give you lots of very useful info as to what is going on here.
- pepmyster
8.1 Volvo Penta
