Battery voltage loss
- Been thanked: 654 times
Re: Battery voltage loss
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
- pepmyster
8.1 Volvo Penta
One of the main reasons I went with Lithium. We were away from shore power for 7 days and finally plugged in last night at a marina. Bank was still almost full mainly because a short time of generator mornings and evenings for cooking, charging and hot water puts the juice back in at over 100 amps. I have 525W of solar on the roof but this is not enough to sustain my usage. Reason for the marina was the heat expected and we wanted AC to sleep better.
- pepmyster
8.1 Volvo Penta
- Has thanked: 602 times
pepmyster wrote:Source of the post Understood, but if the battery says 170ah, x 4 =680
Reserve capacity is a measurement of time not Amp hours.......Ahr's is the battery capacity and measured as Hans has layed out.
Now that said, you have the tools to figure this out already IF you installed the Victron properly and have all your grounds in the right sequence with the shunt.
You should see power/charge in and draws out at all times on the monitor, easily monitor your fridge usage by watching the monitor and shut off all but the fridge and see what the draws are. That would apply to all your loads attached to that battery bank that the shunt/Victron monitor is attached to.
How many of these batteries are on that bank you are using for house?? Just 3 small grp27 could quite easily be the problem here as could be the fridge....lets face it it has been quite hot and humid lately taxing everything to the max....maybe you found the breaking point.
- pepmyster
8.1 Volvo Penta
pepmyster wrote:Source of the post Understood, but if the battery says 170ah, x 4 =680. This is going to make me lose my mind! Can't afford to go the lithium route. 340 watts of solar pumping 14 volts at 12 to 14 amps on a good have decent sunny day? Think I'm going to buy a kayak.....
I believe the confusion is the AH vs Reserve in your case. Here is a typical group 27 deep cycle. The reserve is 175 however the AH rating is 80. I seriously doubt you will get 170AH from a group 27.
https://www.napacanada.com/en/p/CNB27RVS
