Bow thruster oil change
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Thanks in advance!
Re: Bow thruster oil change
- pepmyster
8.1 Volvo Penta
Personally I think it is a good idea to have a bottle to be able to see if the fluid gets discolored which could be the telltale of an issue or milky which would indicate water intrusion.
Both my thrusters have never had an oil change yet, oil in the bottles looks like new. The gears rotate for what? Maybe 5-10 minutes a year and that would be a generous figure. Inspecting the motor part reveals no motor brush dust which indicates very light usage. You be the judge of what you think is required.
You could have a few percent water in there and still not make the oil milky at all.
km1125 wrote:Source of the post I think the issue is really water contamination, just like a lower unit on an outboard or outdrive. Doesn't take much at all to start doing long-term damage. You could probably drain it all and re-use some of it to refill... but with such small quantities, what's the real value in doing that?
I agree but what about their newer models which are sealed for life? Sealed for life does not exist in my book being a very bad idea IMHO. Many of todays automatic transmissions on cars are the same, no way to check level or change oil or maybe I should say no easy way of doing so.
- Has thanked: 603 times
Does the oil in the thruster motor area circulate thru the reservoir or is the reservoir just there to keep the motor area full ?
Could you actually get the oil from the gear case then ? ...only asking, never done this as never had bow thruster like that.
Users browsing this forum: Beachlovers and 21 guests
