Fireboy-Xintex Gas Fume Detector alarm
- BiggerBoat
- Vessel Info: 1988 Carver 4227 CPMY
Twin Mercruiser MEI 340 - Location: Stillwater, MN
- Has thanked: 4 times
I'm assuming the unit fault indicator means the gas fume sensor is bad. Is this a good assumption?
If so, I cannot find the sensor! Have searched all over the engine room. Any ideas where that sensor might be located??
Thank you
1988 4227
Stillwater MN
Re: Fireboy-Xintex Gas Fume Detector alarm
- Has thanked: 602 times
- Been thanked: 1310 times
- Been thanked: 1111 times
If it is a bilge sensor then should be located low on a bulkhead, but not so low that it could get wet from water splashing around in the bilge. Mine were always mounted about 1/2 way down the bulkhead. You might end up having to follow some wiring if you can't find it.
Looks like this is the model for you detectors. On the Xintex site it looks like they are discontinued.
This is what the newer Xintex detectors use, but they don't seem to be compatible with the older panels
This is the type that mine used, but mine were mounted on an off-white round base instead of this rectangular black box.
This is the replaceable sensor itself (at least on the version I used, and on the hand-held detector I have):
- BiggerBoat
1988 4227
Stillwater MN
Users browsing this forum: No registered users and 54 guests
