Santego 3867 replace packing in the water?
- bobwhorn
- Vessel Info: 1989 Carver Santego 3867. Repowered with Cat 3116s in 1993.
- Has thanked: 3 times
- Contact:
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Santego 3867 replace packing in the water?
- Has thanked: 78 times
- Been thanked: 1093 times
Take the packing nut back from the stuffing box. Wrap the rubber strip overlapping the threads and the prop shaft and wrap a couple times. That will pretty much seal any leak. Then you can either zip-tie it or put a clamp or even just some electrical tape to hold it, while you work on getting the old packing out of the nut and the new packing in place. You can take your time and get it 100% right. Then pull the rubber strip off and start threading the nut back on.
- bobwhorn
- Contact:
- bobwhorn
- Contact:
Thanks,
Bob
