Oil Pressure Sender
Cork the Whine
Vessel Info: 1997, 355AC
Has thanked: 20 times
Been thanked: 11 times
Oil Pressure Sender
Postby Cork the Whine » August 14th, 2023, 7:18 am
Good morning! We own a 97' 355AC w/ Crusader 454 XLi's, throttle body injected. My starboard engine is showing 80psi at the helm regardless of the engine speed when the engine runs. The gauge itself is working, I swapped the port and starboard gauges this past weekend. I'd like to replace the sender on engine but I'm not sure if I need a single station send or dual station sender. I only have one helm, the flybridge. Any suggestions would be apprecaited.
Cheers!
Re: Oil Pressure Sender
Postby bud37 » August 14th, 2023, 7:42 am
If you only have one station/helm/one oil pressure gauge per sender, then that is single station. I think there may be some id numbers on the sender itself as well, at least the ones I have seen.
Postby g36 » August 14th, 2023, 9:07 am
Yes single station. I believe this is the part your looking for.
Crusader R020001
MyPleasure
Has thanked: 2 times
Been thanked: 23 times
Postby MyPleasure » September 24th, 2023, 9:19 pm
Hi, I have twin engines, but only one sending unit for both stations.
Al
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
Postby bud37 » September 25th, 2023, 4:41 pm
MyPleasure wrote:Source of the post but only one sending unit for both stations.
By this do you mean for each engine or you have twin stations ?
