Maxwell 800 Windlass
Re: Maxwell 800 Windlass
- Wayne162
- Captain
"Change In Latitude"
Home port - Charleston, South Carolina - Has thanked: 16 times
- Been thanked: 32 times
- Contact:
Thanks for the information. I should hear back this week from Maxwell and I will ask these questions.
- Wayne162
- Captain
- Contact:
I don't see a chain stop set up. Every windlass installation with the exception of some special designs should incorporate this. In your case, you can utilize the cable design and fasten it to the cleat. These grab the chain when anchored out, and transfer the load to the cleat rather than the windlass hardware. It also serves as a safety hold in case the clutch loosens up while you're under way, thus preventing your anchor from dropping, bouncing off the water and smashing into your hull. Seen it happen many times.
There are many styles and brands out there. Here are some examples:
http://www.westmarine.com/buy/lewmar--chain-stoppers--P005_155_002_501
You would use something similar to this one for fastening to the cleat
https://mcpartsdepot.com/products/lanyard-anchor-retainer-265-08-14-255-x55-09-14-chain-stop-for-windlass
http://www.westmarine.com/search?Ntt=anchor+chain+tensioner
- Wayne162
- Captain
- Contact:
- Wayne162
- Captain
- Contact:
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
- Wayne162
- Captain
- Contact:
I actually never had the chance to use this windlass. I recently purchased this boat and had problems with the windlass from the beginning. The surveyor checked that it had power and did not operate it. The motor was still good and powered up. When I tried to use it I knew it needed to be repaired or replaced. During replacement, I removed all the chain and rope from the locker to clean it out. I found additional pressure arm pieces, sand, paper, etc. at the bottom with other unknown mechanical debris. The chain wheel housing also had no pressure arm when removed. It was time to go !Thanks for the advice though.........
